TwinTurbo.NET: Nissan 300ZX forum - Re: Thanks- are the connectors under the footwell or in door? Tx
ttz'in (norcal)
on May 02, 2015 at 1:54 PM
Thanks- are the connectors under the footwell or in door? Tx (n/m)
posted by stockplayerz(nyc)
on May 02, 2015 at 06:04 AM
One connector (key illumination) is on bracket mounted to steering column. Don't recall where floor courtesy light connector is mounted, but same area.
HELP!! 10A fuse keeps blowing out instantly >>
stockplayerz(nyc)
09:11:54 05/01/15
One thing to check, the stock Bose system had powered amps
jzack
10:50:47 05/01/15
oh very interesting- definitely a starting point to check >>
stockplayerz(nyc)
11:06:01 05/01/15
look for a lonely wire thats just taking up space (n/m)
LivinTheDream
15:24:35 05/01/15
Michael, had a similar issue with the 10 amp fuse,
ttz'in (norcal)
19:23:24 05/01/15
stockplayerz(nyc)
06:04:54 05/02/15
Re: Thanks- are the connectors under the footwell or in door? Tx -
ttz'in (norcal)
13:54:23 05/02/15
UPDATE >>
stockplayerz(nyc)
06:21:51 05/02/15
FOUND IT! One step closer >>
stockplayerz(nyc)
09:40:26 05/02/15
Actuator and door wiring is different between the years
ZXoltan
10:03:07 05/02/15
Thanks- this may be more challenging than I thought >>
stockplayerz(nyc)
10:46:19 05/02/15
Should have kept the wiring and guts from your old door :-O
ZXoltan
11:04:30 05/02/15
yes- lesson learned >>
stockplayerz(nyc)
11:57:12 05/02/15
May also affect the security system ?
ttz'in (norcal)
13:57:38 05/02/15
Get this from him. Be done with it :) (n/m)
Zuberman
21:51:02 05/02/15
Are u sure the 90 2+2 is exactly same as 91 TT ?
ZXoltan
10:24:30 05/04/15
I think your question is for ttz'in since he is the one who
Zuberman
11:32:42 05/04/15
For both of you since you said "get this from him" lol (n/m)
ZXoltan
13:10:50 05/04/15
Not speaking for anyone else, but what I would do is print
Zuberman
13:46:26 05/04/15
THANKS for all the suggestions, the only issue is >>
stockplayerz(nyc)
13:59:56 05/06/15
I'm not positive, but if you disconnect the hood security
Zuberman
13:35:53 05/08/15
Not sure about a '91TT being the same, but
ttz'in (norcal)
13:46:27 05/04/15
